Lost OTA signal on 1 and 1/2 channels | SatelliteGuys.US
ctjr
155
I say "1 and 1/2" because one OTA channel is gone completely... shows "0%" strength, and the other channel shows "0" for a brief second and then switches back to it's normal strength of 74-75%.
The channel that is out completely usually comes in around 89-90%.
My 3rd major that I usually get OTA is operating normally, coming in instantly at 97%
Seems strange that one of the OTAs is unaffected, one is partially affected and one is completely "gone."
AFAIK, I do not have the update yet. I did a re-scan as well as unplugging, but neither did any good.
Any ideas?
Actually, it turns out is is BOTH of the stations. The one station (from what a few others in the area tell me) ALWAYS takes that second or so to lock in. I never notice because everything I watch on there is recorded. The one that's completely out turns out the station is waiting for a part (during the Final 4 no less).
One thing I have noticed on both of my 622s -- if you go to the channel that "isn't there" and see the yellow screen and then go to any other station, the 622 cuts out and has to be reset. Wierd.
several problems with my VIP211
Question regarding Dish 501 and internal code
