Lost 12:04AM CH 9469 SAT 129 TP19 - After Repoint... | SatelliteGuys.US
FCom911
287
SAT 129 is acting up... and this time, a bit more seriously, this AM... Signal loss (ERROR CODE 002) after my recent repositioning...
As previously mentioned, HD Only package... after repoint w/1000.2, 129 SAT reception was solid for about 30-45 days.
Now...? 002 Signal Loss Error at 12:04A.M., is simply pushing the issue, at bit further...
It's apparent, Ceil2 replacement is needed... sooner, than later.
Recap: Leased slot, 129 has lost 12 solar panels, unable to run at designed power output, reported in the most recent of Dish Network's S.E.C. reports; two panels failing in the last quarter alone... Repositioning requirements, approximately 2x per hour... believe power and orbital fuel status are entering an inescapable, precarious point...
I haven't seen any serious issues with 129. It is weak, but I can usually get 50; 17 is minimum usable.
What's your current signal strength?
Maybe your dish has simply moved again, try a repoint before jumping to conclusions.
Why not use one of the previous 563003600 threads on 129, rather than starting the discussion over again at the beginning ? :eek:
Did you forget already? FCom is responsible for starting new threads for any subject that rolls off the first page of threads. He is doing a fabulous job! :D
Two dishes
Cost to upgrade from VIP 622 to VIP 722
