losing signal | SatelliteGuys.US
losing signal
honycutt
3
I hate to post when I know that the answer is somewhere on the page But I couldn't find anything close.
I live in Tallahassee Fla, Tree capital of the world. I have a winegard GS 2200 OTA atenna and alll the towers are within 23 miles. Pretty much all in same direction but I'm shooting through a bunch of trees. I get a good signal, 80 to 95% and then it drops to 60% and then not aquired for a second but goes right back to 95%.
Is there anything I can do to improve the signal?
I hate trees
Your antenna is not directional enough and you are getting multi-path (reflections/Ghosts).
Currently all the channels are UHF except WTWC-DT which is channel 2 (UGH!), but they will be moving to channel 40 in Feb. 2009.
Get yourself a small UHF yagi antenna like the RS U75-R ($30) and point it at the stations you want to receive.
You might even get 24 and 32 off the back side.
honycutt, good luck, I stayed just east of Tallahassee (I-10, exit 217) about a year ago at a road travelcenter tested and found this place sucks for easy broadcast DTV reception. I found out I was in a fringe receive area for Tallahassee / Albany DMA even looked up the db coverage maps. good luck.
Agree with Jim sounds like multipath, your Winegard Sensar III is not very directional receiving about equally well from front and back and a little rejection from the ends.
which ant.
Trouble with KTLA?
