Looking for: Panasonic TU-IRD20 | SatelliteGuys.US
m3repair
89
Niagra Falls
Forgive me if I am posting in the wrong spot, (feel free to move if need be) I am on the hunt for an old direct tv receiver don't know if anyone has any panasonic models but my grandmother doesn't want to change her panasonic receiver but wants another one in her bedroom, If you have one could you please PM me, I can be HD or SD doesn't matter, its just the layout for her is easy to use as she has a hard time changing to new things but please feel free to pm me!
Well, if it's a Panasonic you need, it WON'T be HD as they don't make one.
It will only get the 101, 110 and 119 Sats, which the Core programming is on the 101, nothing is on the 110 and theres a little programming on the 119, mostly music and international (I think thats all thats there)
I believe panasonic did make an HD model, but it stated I was looking for HD OR SD model, didn't matter, I know there has to be one out there somewhere I would prefer the same model of course which is the Panasonic TU-IRD20 or TU-IRD10, and its ok if it only sees 101,110,119 as thats all thats needed
You will get very little HD, is what I was trying to say as most of the HD is in Mpeg4 on the 99 and 103 Sats, ones the Panasonic your looking for won't see.
If your only looking for SD, then the 101 is the only Sat you really need.
Thats what I had thought, and most of the channels she watchs anyways are on 101 so it doesn't make much of a difference in this case, so a SD receiver would be ideal if not an HD model could just see 101 and that would also be ok seeing on HD, been hunting on ebay and so far no luck, not sure where else to look, she has a CRT tv so that should tell you the entire picture lol
The second generation of RCA DSS receiver like the DRD303RA has the same menu as the Panasonic your interested in, just a different color.
I may have the old RCA 221/222 's sitting around if I didn't get rid of them, would they be the same ?
DIRECT TV Rewards Visa Defaulting on Rewards Redemption
NFL RZC asking if I want to purchase
