Looking for installer | SatelliteGuys.US
Irenefrances
2
Central Fl
I have 2 questions:
1. I have Dish tv hookup....can I also have fta satellite hookup at the same time?
2. I have inherited a large mesh satellite antenna, a Motorola DSR922 receiver and surge protector. Where can I find someone to install the receiver if it is possible.
Thanks for listening to me.
irenefrances:confused: in Central Florida
Hi>of course you can have Dishnetwork and a free to air setup at the same time. Just have to keep the equipment separate, you'll need a bigger dish than they use, 36-39"dish for free to air.
Is the big dish already setup on a pole, etc? Cable run to it from the house?
installer help
Hello Sir,
Thanks for a speedy reply. Yes, there is a large 8-10 ft. mesh satellite antenna in the yard on a pole, with wires running into the house, andcoming out of the wall by the TV. I think everything is in working order, I just can't wire this mess up Thanks, irenefrances
There are plenty of folks here that will help you sort it out for yourself. You've got the hardest part already done.
If you can post pictures of your dish, that would be a start.
Hi Irene, I'm also located in Central Florida and have been known to work for beer :)
Send me a PM.
Got to run, DC
Dolby Digital 1+1 Audio Track!
After the storm
