Looking for cheap alternative to Scientific Atlanta D9887 -to receive HD digital feed | SatelliteGuys.US
mikebrown
Medford, Oregon
Hi, can anyone suggest a cheap satellite receiver suitable for receiving an HD digital feed...
I want to receive the following feed:
Channel: CBN
Satellite: Galaxy 28, 89degrees West
Bandwidth: 9MHz
Downlink: 3946.5 MHz
Polarity: Vertical
Encoding: MPEG-4 DVB
Conditional Access: None (FTA)
Modulation: QPSK
Symbol Rate 6.113MSym/s
DataRate: 8MB/s
Video: 1080i/59.94
The broadcaster recommends using a Scientific Atlanta D9887 or D9854. I'm interested to know if there is a cheaper receiver that would work (rather than paying thousands $$??
Thanks, Mike.
I say a cheap HD FTA receiver that does MPEG4 would do just fine. Examples like:
Coolsat 8000HD
Coolsat 8100HD
Diamond 9000HD
Neusat 9000HD
Just look for mpeg4 when looking for an FTA receiver. A lot of them only do Mpeg2 so look for that detail.
Is that the same GBN that is on 72W KU? 12144mhz Vertical? It's a gospel channel
that's been there a long time, but not HD.
edit: I just checked, that channel is still active on 72w right now. (they're explaining how dancing is wrong,
because its a prelude to 'other things".
The signal is not up 24/7. It's a CBN feed. The usually have an SD and HD feed. Both are DVB, but HD uses H.264.
I would think if its not encrypted then a Pansat 9200 would work fine. Correct me if I am wrong?
Viewsat questions
Did ya ever buy and built kits from Ramsey Electronics?
