Looking for Channel Master Pgm | SatelliteGuys.US
WeakSignal
Help,
I am looking to download a program to edit my channels for my Coolsat 5000 receiver channels and I think it is called Channel Master.
Can any1 point me to a download cite?
Also the Coolsats do not work directly with Channel Master so you will need the Coolsat Loader, I did a search and could not find it here on the site, I though it was here, I have the loader if you can not find it (I will upload it if you can't find it).
the coolsat will allow you to rename a unused satellite (or satellite you might not use) but i tend to find it easier to use a channel editor and add or rename satellites with their current name. i also like the basic coolsat editor for this process although Channel Master does offer more bells and whistles.
On older software, 97w might have been called Telstar 5 or IntelsatAmericas (IA) 5. It is currently called Galaxy 25. All refer to the same satellite.
DiseqC Switch Questions
LNB & Motor for 1.2m Andrew?
