looking for c-band mesh and cut | SatelliteGuys.US
i4tas
791
4
Northern USA
anyone have any extra mesh and the ability to cut it?
I had some used mesh that i tried to cut, but cutting it straight and crisp isn't easy.
I would guess that if you are using aluminum mesh it would need to be sheared on a metal shear. Try a sheet metal shop they may be able to help you.
as far as mesh, I have some, but it'll be used for the 12' Paraclipse that is waiting on me to harvest it, and the rest I've promised to Brother Tron for HIS Paraclipse.
I'd suggest harvesting a cband dish that may be less than desirable and get the mesh that way. :)
Make templates of the panel out of cardboard, then transfer to a sheet of plywood and then cut it out of plywood x 2 and then clamp the metal between the two templates of plywood with some overhang and then just cut it out using a saber saw.
Ok I got my hands an on another 10 foot orbitron. I have 14 perfect pannels and 4 panels that have minor bends. If anyone needs some, PM me, as I have more than enough.
Good Old Days or Good New Days of c-band?
c-band satellite equipment requirements
