Looking for Advise on a new TV/Sat setup | SatelliteGuys.US
jkohnman
100
Hi,
Thought I'd look for advice here since everyone knows so much on the subject :)
My current setup is dying, so I'm thinking I'd upgrade since I've got to replace things anyway.
I've attached a picture of my current setup to hopefully make it clearer. I'd like to go with an HD setup, but I'm so lost as to how the HD world works.
What I have in mind is a LCD as big as I can fit. The opening on the cabinet is 44" wide, and I could squeeze another 3/4" going behind the trim. From what I can see a 46" screen is about as big as I can get in the opening. I could go to 50-55" screen if I can figure out a cool method to mount the TV in FRONT of the opening. The cabinet is 27" deep, so from what I could see that's just a little too deep for an extension mount. So I'm looking to see what you all think. I do not want to cut or damage the cabinet, but I can build things, so I was thinking some kind of false wall behind it to mount it too? I'm just not sure how secure it would have to be. (The opening is 55" high, so I think I'm good there)
I'm also looking at a new Dish PVR and am wondering which is the best HD one they have?
I would need a receiver also (main part that's failing now) and my thought is I would get one with HDMI in and out, them plug everything into that with the output going to the TV? The ones I've looked at so far do not have inputs for turntables, is this the norm now? Is there a flaw in this thinking?
When done, I would like to have it setup for Dish box, computer, Blu-ray or Playstation/Blu-Ray. I have an internet switch behind the current TV and I'd like to have that hooked in to the computer for Netflix streaming, and other internet stuff.
I know this is a long post, but I really don't know where to start right now. The TV part is the stuff that's really throwing me. Any help or advice would be much appreciated.
Jim
Hi,
Jim
I had a Toshiba 61" projection TV in a media center like this one....
http://images.hayneedle.com/mgen/master:WCL300.jpg
When I went to HD, I bought a samsung 67a750 projection to put in its place. It is a nice TV and is only about 16" deep.
I had the problem where the TV wasn't as tall and I had not way to put it in the same spot. I didn't really want to trash my entertaiment center so I bought a TV stand that fit in the same spot and wa about the same color as the entertainment center.
The depth wasn't really an issue since I just placed it flush with the entertainment center.
Crutchfield has a wizard that help give you an idea of what will fit.
http://www.crutchfield.com/S-Wx1LWKzOtUx/App/Tools/TVFitFinder.aspx?view=1
You would probably need to go with a phono pre-amp like this one.
Audio-Technica AT-PEQ3 Phono preamplifier at Crutchfield.com
You can do hdmi switching for your inputs.
Sorry to break up your post. :D
Post back if you have more questions.
Saving a program to DVD or laptop?
Special Retailer Chat Recap - August 24th, 2009
