I currently have a Glorystar system and am using 4 different receivers in 4 rooms. The one Topfield receiver that I was using died. Is there an inexpensive replacement for this receiver? Thanks.
Really any receiver out there will work.
If you went with a GeosatPro that has the "Glorystar" option in the software where it loads all the G* approved channels.
If you went with any old receiver (Pansats, Fortecs, Coolsats are good) you would have to scan in the channels and delete the ones you dont want (there are lots of ethnic channels on that same satellite). Most of those can be had for under $50 on Ebay
For example, looking at Coolsat 5000 on ebay, you'll see one for $38.00 with free shipping. There are others listed as well. The Coolsat 5000 is a quite decent receiver.
