Logos Missing (HR44) | SatelliteGuys.US
cditty
1,293
35
Northeast Louisiana
Last week, my logo's vanished on my Genie/HR44... I expected them to return, but I have done a reboot (yesterday) and it's still just text.
Is this a known issue? If so, does anyone have fix?
Do a smart search (like you're looking for a TV show) with CLEARMYBOX 2 as the title (note the space). Hit the red button - nothing will happen for a few seconds, then your box will completely reset. I have done that probably 4 or 5 times total and logos and such are back within 36 hours and I don't lose my settings and my recording list. However, immediately after doing this, your playlist and other things will not be there, they return usually in a few hours. I have found it best to do it before bed, after all recordings are done and none are upcoming for at least 12 hours.
i had mine logos missing once, and i try everything even CLEARMYBOX, nothing work, you need to wait and its might days or weeks , for its was about 3 weeks , and i tried CLEARMYBOX also
Whats the difference between CLEARMYBOX and CLEARMYBOX 2
I didn't know the difference, great info! I suspected that "2" was to keep recordings or something. To the OP, do what I said - but not the space and 2!
What happen to KENW-DT out of Portales, NM?
Need Replacement DVR w/o tech coming out
