Locked at 61.5W Tp5 wit Signal Strength 35-41 but unable to Acquire Satellite | SatelliteGuys.US
areafix
7
Montreal
This is my first installation of 1k4 + ViP722K.
61.5W shows up as a green box on Port 3 after running Check Switch (72&77 - connected but no signal)
Acutrac 22 detects a good signal on all 3 LNBs but my DVR is unable to download software from satellite.
Is there any way to upgrade DVR software from PC?
Thanks in advance.
After running a checkswitch, go back to signal strength screen, set to 61.5 tp 11, rec should scan for avail sats
and will probably go back to tp 1 on its own which is a spotbeam
Set it back to tp 11 until it locks in and select done.
It should download from there
I finally got a clue:
when using 1000.4 dish we need 72.7 to get the DVR activated.
My Vip722K was able to download software as soon as I re-pointed 1k4 and got a signal strength about 50-55 on 72.7
So, problem is now solved.
Thanks guys for your help!
MotoSat on Motorhome Problems Help Please
Interesting...
