ke4est said:this has been posted and answered before, but because your new, I will answer it for you. BTW welcome to sat. guys.
Ok #1 there is no master password.
So if your parents have you locked of of certain channels give up.
#2 if you are and older and own this system and have forgotten your password the only way to get it reset is to call....1-800-333-3474 and tell them what the prob is. They will ask you some questions to verify you are who you are and then they and only they can reset your password to the default.
hope this helps
ke4est
jpezz said:No! I am my father."
onsiteSat said:Here is a quick fix for Removing passwords (along with everthing else)
WARNING THIS WILL RESET YOUR RECIEVER COMPLETELY ALL SETTINGS WILL BE ERASED!
This will erase Favorites Lists, Passwords, Check Switch status, and Timers.
DVR recordings will stay as well as programing.
<deleted>
This Only works on old 1st 2nd and 3rd gen recievers
Note: Doesn't work on 301, 311, 501, 508, 510, 322, 522, 942, 721, 921 , 7100, or 7200 Recievers
Limited time offer
