local hdtv recording | SatelliteGuys.US
mlrtime3
47
Sorry if this is a basic question, I couldn't find an answer.
I have the 622 with HD NYC locals. I set a timer to record "criminal minds" on CBS. When I setup the timer I selected the show on CBS HD Channel 6301.
However, when I tried to watch the show, I saw that it recorded in SD on channel 8101.
Is there any way to force the HD version? When I view the timer it doesn't look like the channel is anywhere as an option.
now that hd priority map down is working, you should be able to record from say 004-00 wnbc and have it HD.
What procedure did you use to set up the timer? I have not had that problem. By the way, mapping down is not working on my 622 but that's another post.
If you are using Dish Pass then it will record the first channel it finds that meets the specifications you selected.
622 goes black and then screems
Dish 300 @ 105
