Local Channels... | SatelliteGuys.US
Local Channels...
coach Al
19
Greer, SC
I've been using my SA satellite for a few months now and we have just cancelled out our local cable (wanted to make sure the SA was for us). :)
Local channels are not coming in too good. (I DO NOT want to pay for local channels) Should we put up an aeiral antenna to get these? Or can the satellite dish be used as the antenna?
thanks for the replies...
Al
You will have to put up an antenna. The sat dish will not work.
Go to http://www.antennaweb.org enter your address and it will tell you what kind of antenna you will need and which direction from your house the stations are.
Super Bowl Alternative Halftime Show on Angel 2
tln network to join skyangel
