Local Channels | SatelliteGuys.US
Local Channels
jdubs
7
Saint Louis, MO
The local channels on the guide are not updating. I only have programming for the next two hours. Any ideas on how to fix this? I have restarted the system already.
Thanks!
Press the menu button on the remote.
Then press 6 on the remote
then press 1 on the remote
then press 1 again on the remote.
This puts you in the point dish screen. Select "Check Switch" Wait. When done press okay or done or cancel depending on the model.
Wait for the guide to be loaded. (takes 5 minutes or so)
Good luck.
See ya
Tony
New install plan: please check my DishMath
History Channel HD
