Local Channels question..... | SatelliteGuys.US
deleteduser
2
Hey guys! I just have a quick question i was wondering someone could help me with about my local channels. I can't find them on my satalite anymore. I don't understand what has happened to them. I have unplugged the box, i have turned the power button off and still no local channels. I'm going to call dish network but since it's annoying, i figured i'd ask on here. Anyone know what my problem could be?
silversurfer01973 said:
Welcome to Satelliteguys! We are glad you are here! I will move this to the correct forum so your question can be answered quickly....
Why would his post get moved it is a DISH Network ?
If moved where to?
trido
When you add Digital channels, the local display is sometimes eliminated. Go to the Add Locals option in the set and use the Display option. Pick Dish Locals and check it, save and you should see the locals again.
Pete
Are you talking about over the air locals that the 811 or 921 will let you pick up, or Dish provided locals?
If it is Dish provided locals:
Are they not showing up in the guide? If not, reset and call Dish if that doesn't work.
No audio on play back?
Should I upgrade to an 811?
