Local Channel Skipping | SatelliteGuys.US
Does it happen on all your receivers, or do you have only the one? If it does happen on more than one receiver it's probably an issue from the POP.
Send a quick e-mail to DishQuality@echostar.com with as much detail as you can. If it is a problem with the local channel at the POP, they will fix it quickly.
Be sure to include the channel number, call letters, Dish Channel number (in the 5000, 8000 or 9000 range) the city the local is from and of course a way they can contact you. They usually respond by e-mail.
Joey Remote
DPP44 Switch Purchase Price
