Local Channel On HD | SatelliteGuys.US
Local Channel On HD
Shirke
17
Anyone know when KCAL 9 Los Angeles area HD to be delivered via Dishnetwok satellite?
I don't myself, but I would like to welcome you to Satelliteguys!!!
Dish Network installer here,
I don't know how close you are to where you live compared to where the local station is broadcast from.. but connect an off air antenna to the rear of your receiver and do a local scan. If you are able to pick it up it will add the network to your channel guide..
if your close you can use bunny ears.. if you have a great distance to go.. try a larger off air antenna on your roof or something. Again, not knowing the situation your in .. dont know if this is an option for you.
Testing Enhanced Weather
Possible DVR upgrade
