Call me crazy, but I've noticed a few times recently where DirecTV has somehow managed to inject local ads into national network commercial breaks, something I've only seen from regional cable operators. Anyone know how this works?
Actually they are inserted by your DVR. DirecTV downloads them to your DVR, and then your DVR inserts them, I assume by zip code. The local-in-local origination points (called Local Receive Facilities) only uplink the signals through one of DirecTV's main facilities to the satellite, they don't add anything.I've noticed the same thing since about this time last year. I'm guessing the ads are inserted at the local-in-local origination points (there's one in each market served by the DBS companies, usually at a local station). I'm in Los Angeles, so far I've only see local/regional ads for a car dealership from one of the suburbs, and for Carl's Jr.
Not necessarily. The one I saw for Aco hardware was in HD when I was watching ESPN the other day.yup they've been doing that for a while now. They're usually easy to spot as they are in SD![]()
So are they downloaded to the DVR via satellite or internet connection?
and what sucks most is that volume is two times louder than regular programming.
Thank you.I was going toyou to Satelliteguys MozartMan since this is your first post, but you have been a member for over seven years!
Limited time offer
