lnbf trouble? | SatelliteGuys.US
lnbf trouble?
keish24
4
hello,
I have complete signal loss with the error code 11-12-11. The set up is a dish 1000 connected to a vip 211k and a solo 311. neither receivers are getting signal and all sattellites are showing red x on the signal test. I am thinking that it has to be a bad lnbf. can anyone verify this or offer me any help?
If you have a dish 1000/1000.2/1000.4 you have 3 LNBs so a failure of 3 at once is doubtful, look for a bad switch or another cabling problem.
hello,
That signal code deciphers to: a response was received from the LNB. The LNB is indicating lost lock on the satellites. No weather event, not reset before the signal code. Device check and DiSEqC match the matrix.
Go to Point Dish screen (menu, 6, 1, 1). Go to Check Switch, then Test. If test goes to 1 of 4, the receiver sees the dish but has signal issues (may be alignment). If it stays at 1 of 1 for two minutes or goes to 1 of 38, the receiver does not recognize the LNB. Then it could be the LNB or a common problem somewhere else in the lines. Do that test first though.
vip722k hook-up
Memphis, Tn with balcony on East Side: Can I get dish?
