LNB.. which one? | SatelliteGuys.US
LNB.. which one?
aamert
39
I have a Dish 500 dish right now..
and i was wondering which LNB should work with it(since it doesnt have one)..
will the dish pro dual lnb be fine with it? or a different one??
the pic of the above one is attached
Thanks,
I think you might get a more complete answer if you provided a little more info.
How many dishes will you have ? Will you have more than just the d500, How many receivers will you be connecting to, and what type. Dual tuner or single tuner. Im sure there's more questions.
details
alright lets get into details
Currently i have ONE dish 500 connected to my dvr 625 (with 2 input coming from the satellite both going into the DVR-dual tuner)
this works fine..
BUT i am going to add a FTA system, so i have a another dish 500 which has a defective lnb (i think) and i would need to buy a LNB for it(as stated above)..
In the end what i plan to do is.. Have 2 connections coming out from each of my dish 500, one from each going to the DVR and the other one from each going into the FTA reciever?
OR
Should i just leave my current setup alone and instead buy a motorized or separate dish for my FTA system?
Thanks,
i was told that i can connect my fta reciever to an existing 18"dish with the same lnb?
Unless i was mislead
no i am not.
Well according to the above post..
I can still recive some channels, although they might be lame.
I guess i need to do more research about fta then..
But my actualy question about lnbs got sorta lost..
Forcing "Always Record" State
Comcast Sports West
