LNB Test Failed | SatelliteGuys.US
LNB Test Failed
bkushner
681
2
Audubon, NJ
When I run a Sat test I am getting LNB FAILED!
However, I am having no problems with my system. Any thoughts?
I'd say ignore it. My R15-300 has this come and go with different versions of the software and none of my receivers are having a problem.
Yes you are correct. I was on a CE release from last week. Just reverted back to the current version and the LNB Failure is gone.
I had the same thing happen a few months back on an H20-100. Advice I received was "ignore it." I did and, eventually, I got a "passed" indication. I also haven't retested since then due to everything working fine. Good luck.
Yes, there were issues with some of the CE's from last week, try the CE for this week if your into it and you probably will find that it is resolved this week.
Every once in a while you'll find an issue like last weeks ...
By us reporting issues in the forums help D* greatly in getting software implimented for new "NR" 's going to the general public.
Jimbo
WHO's IN CHARGE AT DIRECTV
R15 Receiver an IR/RF Remote
