LNB setting? | SatelliteGuys.US
LNB setting?
JackR
17
I just installed the Invacom QPH-031 LNB.
Can anyone tell me the correct LNB TYPE setting to use.
Using the STANDARD setting I get LNB Local-freq- 10750.
Using the SINGLE STACK setting I get LNB Local-freq- 10750(V)/10175(H).
Equipment:
Pansat 3500S
Motor SG2100
Invacom QPH-031
Diseqc 4 way switch
Jack
The linear side is Standard L.O. 10750
The Circular side has L.O. 11250
OK Pete - thanks for the settings. Will try this afternoon.
Jack
Just got back from Europe
Stab HH90 and Foretec 36" install help.
