tjwagner said:I have the H20 and a 3 LNB DTV dish. If I buy a 5 LNB dish so I can get the locals in HD, is it an easy install/switch out that I can do myself? In other words, will I need to run any additional cable through my attic?
If you are very very technically capable attempt it yourself otherwise let Directv do it.tjwagner said:I have the H20 and a 3 LNB DTV dish. If I buy a 5 LNB dish so I can get the locals in HD, is it an easy install/switch out that I can do myself? In other words, will I need to run any additional cable through my attic?
dragon002 said:why are you self installing?
tjwagner said:Tampa...yes
Limited time offer
