LNB help! | SatelliteGuys.US
LNB help!
hobojoe
492
so caif usa
whats the difference between dish and dtv lbn's? is there anything being broadcasted in ka? what is a very good all around general use lbn? when i put a directv lbn on my motorized .98m dish with a panasat 2700 i get dishnetwork when i tried a dtv lbn i get nothing??? the cheap lbn i got with the fta package gets nothing???:confused:
I think you mean LNB :)
Most of the older LNB"s (regardless of what it was designed for) will work. Its when you get into the Phase III LNB (which is 3 LNB's molded together) and the Dish twin (2 LNB's together) then you have issues.
But the older DirecTv or Dish Notwork LNB's are interchangable with a FTA system :)
Where is the best place to look for wild feeds?
Aircraft/ATC comms via Satellites
