LNB help | SatelliteGuys.US
LNB help
rhinoabe
Indiana
I have a old dish 500 with the separate LNBs with the SW 21 switch , can I use the one piece dual dish plus LNB in their place? Thanks
If you replace the 2 LNBs and the SW-21 with a DPP Twin LNB it will work with the current Standard definition Tuner receivers such as the 311,625.
Dish Anywhere prompting for IP
Print Channel Compare List
