LNB feed combiner/multiplexer? | SatelliteGuys.US
trinidex
892
I have 2 c-band prime focus and 2 ku-band offset dishes in my garden, each having 2 LNB feeds making a total of 8 LNB cables.
I'd like to combine those 8 cables into a single feed using something like fibre which would run into the house where they would be separated out again into 8 coax cables.
Does anything exist to do this?
TIA
NO.
You can get bandstackers to cut some of that down, but since I have no idea what type of LNBs you are using or what your polarity needs might be, I cannot give you more information.
How many receivers are you using? and does each receive need access to all those feeds?
Righto, so here's more details:
The c-band dishes are using single c-band LNBs, 2 per dish 1 for each polarity. The ku-band LNBs are dual output.
The main focus is the c-band LNBs, as I do use both polarities with 2 receivers. If there was a chance to halve the number of coax cables that'd be great.
Thanks!
Does anyone recognise this antenna ?
CostCo now carrying DirecTv
