B blts SatelliteGuys Pro Original poster Oct 3, 2008 172 0 WNY Aug 27, 2010 #1 I am looking to hook up one of my sd receivers up when we go to our hunting cabin this fall. Can I use any Direct or Dish dish and lnb?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,481 15,284 Mankato, MN Aug 27, 2010 #2 Any DIrectv dish will work. It just has to have the one eyeball (LNB) Dish Network stuff usually has an internal switch and may not work properly
B blts SatelliteGuys Pro Original poster Oct 3, 2008 172 0 WNY Aug 27, 2010 #3 Iceberg said: Any DIrectv dish will work. It just has to have the one eyeball (LNB) Dish Network stuff usually has an internal switch and may not work properly Click to expand... I currently have an 18" Dish Network single LNB with dual outputs on the roof now which is 12 years old from my original setup from Dish Network. Do you think that would work if I just moved it around to the correct location? Thanks Iceberg.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,481 15,284 Mankato, MN Aug 27, 2010 #4 yep that would work too Thats one of the few times where a Dish Network dish/LNB will work with Directv
