lnb band help | SatelliteGuys.US
lnb band help
cilmaviel
United States
hi, was hoping someone here knows what band dishnetwork satellite 118 west is. im pretty sure its ku but im not positive.
also if anyone knows a good commercial supplier that would be great... im needing to order 200 dishes, lnbs and mounts that can play video through. -thanks
Is there a reason you need to know? 118.7 is a FSS satellite, not DBS (only one that we have). Since 119 and 118.7 are so close you can pick them both up using 1 LNB (500+ to get 119/110/118.7).
It's 11.7-12.2 Circular.
Not Linear like most 11.7-12.2.
Dish sells a special lnb which outouts both 118 & 119. Two (2 ) output terminals (1 for each orbital slot) which can then feed a multiswitch.
Sent using SatelliteGuys Android App
To Dish; Drop Putin TV
Multi-sport package
