LNB 0.3db has anyone tested this brand .. | SatelliteGuys.US
moviefreak
8
Has enyone testes a lnb with this characteristics, they are selling it on ebay for 5 dollars plus 9 dollars shipping, I'm wondering if it is good or not...
here is the technical specifications for the lnb..
MODEL:
K-100
RF Input
Input Frequency Range:
Low Band:10.70~11.70GHz
High Band:11.70~12.75GHz
IF Output:
Output Frequency Range: Low Band:950~1950MHz
High Band:1100~2150MHz
OUTPUT CONNECTOR TYPE 75OF Female Connector
Output VSWR 2.5:1(MAX.)
Local Oscillator
L.O. Frequency: Low Band:9.75(GHz)
High Band:10.60(GHz)
L.O. Frequency Stability: (1) +/-1MHz(ROOM TEMPERATURE)
(2)+/-3 MHz(-40*C~~+60*C)
LO. Frequency Phase Noise -55dBc/Hz(@ 1KHz)
-80dBc/Hz(@ 10KHz)
-100dBc/Hz(@100KHz)
Conversion Gain
50dB(min.)
60dB(MAX.)
Gain Flatness(AcrossAny27MHzSegment) 0.3dB(typical)
Output Power@1dBGain Compression 0dBm
Noise Figure 0.3dB(typical)
Image Rejection 45dB(min.)
DC Current Consumption 220 mA (typ.)
Cross POL. Isolation 20dB(Min.)
DC Current Consumption 280mA(MAX.)
Operating Voltage (1)Vertical:11.5~14.0Vdc
(2)Horizontal:16.0~19.0Vdc
(3)HingBand:Continuous22KHz?KHz
Operating Temperature Range:
-40*C+60*C
Look for this description on ebay, to see a picture of the lnb
0.3 dB BRANDNEW UNIVERSAL KU SINGLE LNBF FOR FTA
any advice on a lnb would be appreciated..., I'm looking for 0.3db lnb's since I will be using them on a 65cm dish in south america chile, and i'm wondering if this one is ok or not..
Thanks...
Looks good, nice and cheap. But you just cant beat the QUALITY of the Invacom products IMO. You get what you pay for!
My question is how the heck would I really know it if they sold me a 0.6 lnb and labelled it 0.3? It looks like my 0.3 Digiwave lnb. Maybe one company in Korea or China makes them and different people put their stickers on them.
Feel Like A Sailor..Because All I Found Was Pirates
Help with SG2100 and DBS-2500
