List of Stations that Multi-Cast On DTV | SatelliteGuys.US
A little nitpick.
WLS-TV and WGN-TV would be the analog stations. The Digitals would be WLS-DT and WGN-DT.
Anyhoo...
Pittsburgh, PA multicast stations.
WQED-DT 38
13.1 - no picture, no sound
13.2 - PBS-HD 1080i
13.3 - no picture, no sound
13.4 - no picture, no sound
WCWB-DT 42
22.1 - WB-HD 1080i (often fails to switch to hd feed and get upconverted SD)
22.2 - WB-SD 480p
WPGH-DT 43
53.1 - Fox-HD 720p
53.2 - Fox-SD 480p
Phoenix, AZ
8.1 PBS Hd programming
8.2 In AM PBS Kids (till 5:00pm) Evening same as SD/Analog Broadcast.
15.1 ABC HD programming
15.2 Same as analog programming
15.3 ABC Newsnow.
fkostyn said:
Phoenix, AZ
15.3 ABC Newsnow.
You forgot UPN -
26.1 Upconverted SD
26.2 SD
West Palm Beach, FL
12.1 WPEC-DT
12.2 WPEC Doppler 12000
42.1 WXEL (Daytime) / PBS-HD (Primetime)
42.2 PBS Kids (Daytime only)
42.3 Florida Knowledge Network (Daytime only)
Portland, OR:
KOIN CBS: In all fairness, they shut off the sub channel for a major HD event.
6-1 HD
6-2 SD
KGW NBC
8-1 HD
8-2 SD
KPXG PAX (all channels look horrible)
22-1 SD Normal PAX crap.
22-2 SD Eastern PAX feed.
22-3 SD Religious
22-4 SD Religious
I'm happy to add that our local ABC, FOX, WB, PBS & UPN broadcast a single DTV channel.
Dayton, OH
Here's what I receive, which are all of the Dayton digitals; I live 8.2-8.5 miles from the towers. I know that with a better antenna, where my house is I would be able to receive some stations from Cincinnati & Columbus.
Unless otherwise indicated, the subchannels all show the same content as the analog, and the -HD shows the HD material when available.
The format is:
"XX: CALLSIGN (NETWORK, analog YY) (general notes)" where XX is the allocated digital transmission channel and YY is the normal analog broadcast channel.
"- ZZ.z: NAME (notes)" for each subchannel (PSIP mapped to ZZ.z).
18: WBDT (WB, analog 26)
- 26.1: WBDT-DT
30: WRGT (FOX, analog 45)
- 30.1: WRGT-HD (no PSIP name, apparently no channel remapping either)
- 30.2: WRGT-SD (no PSIP name, apparently no channel remapping either)
41: WHIO (CBS, analog 7)
- 7.1: WHIO-HD
- 7.2: WHIO-SD
50: WDTN (NBC, analog 2)
- 2.1: WDTN-HD
- 2.2: WDTN-D1
51: WKEF (ABC, analog 22)
- 51.1: WKEF_HD (apparently no PSIP channel remapping)
- 51.2: WKEF_SD (apparently no PSIP channel remapping)
58: WPTD (PBS, analog 16) (no .1 subchannel; all have EPG info; some subchannels only available certain timeframes during the day)
- 16.2: 16DT
- 16.3: 16Again (repeated programming from 16DT prime time)
- 16.4: 16 Kids (PBS Kids)
- 16.5: 16Ohio (Ohio specific PBS programming)
- 16.6: 16HD (PBS-HD)
Lubbock Texas MultiCasters
5.1 - KTXT-DT PBS on CH 39 SD
5.3 - KTXT-DT PBSHD on CH 39 HD
11.1 - KCBD-DT NBC on CH 9 HD
11.2 - KCBD-DT NBC on CH 9 SD
11.3 - KCBD-DT Local Weather on CH 9
34.1 - KJTV-DT FOX on CH 35 HD
34.2 - KUPT-DT UPN on CH 35 SD
Jim Smith
Samsung SIR-T351
DishDVR 510
TiVo Series 2 SA
Sony VPH-D50Q Projector for HD (WOW!!!)
Breaking Ground, WBBM in Chicago to show 2 live holiday programs in HD
Truth about antennas
