Laying a 722 on it's side ? | SatelliteGuys.US
DishDave
898
9
let say you put rubber feet on the side opposite the power supply where all the heat is . And you lay it on it's side behind the TV set would that be ok ?
You obvious need to keep the vents clear. Air intake to the fan is on the right side. Vents on bottom and left side. It is clearly not designed for this but it might work ok.
apartment, one cable multiple TV problem
Lost looks scrambled
