I am having problems with my Joey. OTA pixilates, and menu runs slow. This is conventional Hopper no internal sling, and Joey is also standard. I want to make sure I have latest software on both.
It's probably 99% likely that you have the latest software. It's hard not to have it - it comes automatically and you really can't stop it.OTA pixilates... I want to make sure I have latest software on both.
How is the hopper IP connected? Is there a USB WiFi adapter connected to hopper or Joe?
Pixilation is no longer a problem with OTA must have been some type of temporary interference, but Joey is still very slow. The software version is S388. The uninformed dish tech said I had old software and he was going to refresh in the next 10 min. Even I know that he does not have that ability.It's probably 99% likely that you have the latest software. It's hard not to have it - it comes automatically and you really can't stop it.
How long have you had pixellation problem ?
The pixilation problem went away. Must of been some temporary local interference.It's probably 99% likely that you have the latest software. It's hard not to have it - it comes automatically and you really can't stop it.
You should have insisted on staying on the line with him/her until it updatedThe uninformed dish tech said I had old software and he was going to refresh in the next 10 min
Typical of DISH new software breaks a working system. Contact a DIRT rep.I have having the same issues. If I open the guide the live channel top left corner starts crackling and the system now is really slow. Putting in channel numbers is a nightmare. Sometimes I have to open the guide and then input the channel number for it to even recognize. Software before Jan 2015 was running really smooth.
I have the current software and not experiencing any of the above problems, except for slowness, which began long before the update.Typical of DISH new software breaks a working system. Contact a DIRT rep.
Have you done a pull plug reboot of both Hopper and Joey?I have having the same issues. If I open the guide the live channel top left corner starts crackling and the system now is really slow. Putting in channel numbers is a nightmare. Sometimes I have to open the guide and then input the channel number for it to even recognize. Software before Jan 2015 was running really smooth.
And forgot to add I also get the breaking up picture when the guide is open. This was a problem with an earlier version of software that had been resolved.
I have a Hopper and a Hopper With Sling having these exact same issues. To me, it started after a recent update. But in reality, both have hardware issues and are being replaced. Its not a signal issue since it will occur with on demand content. Both systems would pause, become slow, pixilate and now one of them just continually reboots. I have replacements in the mail.
Limited time offer
