L610 Software Bug | SatelliteGuys.US
L610 Software Bug
old corps
1,707
21
Mid-Michigan
Forgive this old fart if I'm posting this in the wrong place but see my post re. the small picture on screen via TV1 on 722 with L610. If TV2's format is toggled to NORMAL on an HD channel the viewable picture via TV1 will shrink down to a very small window in the upper left corner of the screen as soon as you change channels (on TV1). Ah, I just love new software from Dish............GGRRRR:mad::rolleyes:
Ed
saw that a couple times myself. I found that cycling through the PIP windows fixes it (that is if you are in single mode)
I'm in dual mode when it occurs--the wife is watching something via TV2, changes the format and I change channels on TV1. I can "fix" it by changing the aspect ratio in HDTV Setup back and forth between 4x6 and 16x9 without having to reboot but what a PITA. The PIP thing won't work, as you said, in Dual Mode of course.
Ed
1 yr in a rental house, dish already on roof
HBO or PlatinumHD?
