L512 resetting resolution? | SatelliteGuys.US
KAB
22,374
6,405
Fishers, IN
Like others around here lately, I began to notice PQ on both of my 722s to be not as good as usual. I discovered last night that both of my 722s, in HDTV setup, TV Type (resolution) had been set back to 480p. My natural assumption is that L512 caused this because I never did it. I do not know for sure of course. But it makes sense. Anyway, you all might want to go and check your receivers to make sure they're set to where you intended them to be.
Could be DRM implementation - some of program force your DVR to change resolution because it failed HDCP handshake with your TV set.
And how/why would that happen...no premium channels here.
I checked mine last night, was still set @ 720p. If it has to do w/ DRM, it shouldn't affect me, as the TV claims to be HDCP compliant....
So are both of mine. I doubt it was DRM. Software changes have been known to screw with some peoples settings
Problem with 508 DVR...just the drive?
Channels In the new TURBO HD pkgs
