L447 | SatelliteGuys.US
L447
bama350z
42
I recently recieved this update on my 622 and now seem to have OTA audio issues. Is this a problem others are still experiencing?
L446 had audio issues, however the audio problems were fixed in L447.
If you are having problems, unplug your receiver from power and leave it unplugged for about 5 minutes then plug it in. The issue should be gone.
If not, then go into your local channel setup and remove all the channels and save it, then go back in and have your recevier scan for OTA channels.
One of those should fix it. :)
Another new CI channel added
system info screen 613
