Please help! What is the best L.O. Stability, i.e, the Norsat uses the second number in the series to identify, i.e., 8115, 1 being plus or minus 100kHz. Is the higher number better or the lower?
Probably 'cause you'd be disappointed.I wish they'd give stability specs on the LNBF's.
agreed. Im always amazed how a LNB that is rated at 35K seems to be more stable than a LNBF rated at 17K or even 13K
Here in Minnesota where it can get COLD is when the stability really shows
From what I know the colder it is outside the better the LNB likes it. There was an old guy Doug Dennert on the SkyStore back in the late 80's and early 90's. His sat business was out of Minnesota. He used to say that LNB's loved 20 below zero outside and performed great at the cold temps. I have seen back in analog days when noise temps were higher this really held true.
Limited time offer
