kxxv 25 hd missing | SatelliteGuys.US
kxxv 25 hd missing
kxxv local abc channel is missing from the HD channel line-up. I can only get it in sd. Any advice?
The antenna works very well for KXXV. A small indoor UHF antenna connected to the "Off Air" antenna input on your satellite box and scan or add #26 to it. Just select Menu-6-9 and type 26 in the number window and see if you can peak the green signal bar. Hope that helps... I even used a paperclip once and KXXV came in and I live 40 miles south of Waco. Good Luck!
dish 311 receiver and prepaid service
Programming Upgrades for Existing Customers
