King Tailgater pro weather extremes | SatelliteGuys.US
RVlifer
3
Texas
has anyone had below freezing temps affect there Pro, can't find anything on operating temp ranges, will this survive outside temps all year round or is there a max temp where I'd need to bring it in.
I found no operating temperature range listed in King's specs, and the only cold weather related mention in the manual is in reference to snow possibly degrading or blocking the sat signal. No surprise there...
I've used mine while ice fishing in North Dakota, in -20 and worse temps. Make sure you store it in a dry environment when not using, and a stand is necessary to keep it off the ground. These things are not air tight, and water vapor will fog up the dome, and melted snow and evening/morning dew/frost will makes its way into the gears and motor, and then freeze.
Dish vs Space X
Hopper w/Sling.... whole bunch of recorded shows are now gone
