JVC 123470984-AG how to enter codes? | SatelliteGuys.US
manteca
361
10
--- i have this old remote using as emergency replacement until the new remote comes in, how i can enter the codes to control my tv? - thanks! ---
--- thanks for your reply! - i'm getting problems on how to input the codes in the remote, like, which buttons i need to press - i tried holding the mode button, but it will forward to the other device - i see an address button, but don't know if it's the one to use to enter the codes and the correct order ---
Signal strength on 129
Dish channel problems
