Just got my 722 - couple questions. | SatelliteGuys.US
Islandguy43
2,128
Grand Island, NY
I just had my 722 installed on Saturday and hopefully someone can answer a couple questions for me.
On my 211 receiver if push the page up or page down button, it allows me to format my picture to either normal, zoom, etc., however when I do that on the 722, I don't have that feature. I looked in the manual and can't find reference for it, is that feature not available on the 722?
Also, I have the receiver hooked up to the broadband connection (the receiver has confirmed the connection etc), but noticed it didn't download the latest version of the software for the 722. Since it is a brand new reciever, shouldn't automically look for the latest software for the receiver?
Thanks for you help.
Press * to switch the display format on the TV.
The receiver needs to be turned off to be able to download the software update. The latest is L4.45. Actually if it's a new install, you should be at L4.46.
The current software is L4.45, so I will make sure the reciever is turned off tonight, and thanks for the info on how to switch the display format:).
FTA Notice Sent To Retailers
Charge on Dish Statement
