Just found 622 Feature | SatelliteGuys.US
wied
233
2
Wylie, Texas, United States
Some may already know this but I though I would post it anyways. Many people always say they wish E* DVR had the max number of a certain program to keep on the disk. Well the 622 has this feature:
If you press the DVR button 3 times
Then select the timers button
Then select one of your setup timers and press the options button
it has several options here like start and end buffer times but at the very bottom it says max number of recording to keep until oldest unprotected event is deleted and it allows you to select 1-25.
I have not check to see if this options is also on my 522.
Just thought I would share.
If I rub my belly and pat my head three times and flatulate, I turn into Jessica Simpson :D
Just kidding. Anyway, that's good to know. Thanks.;)
Loss HDMI on 211 Unit
New 622 owner, record 2 things at once? How?
