D DishInstallAdam SatelliteGuys Guru Original poster Mar 27, 2011 125 0 Iowa Oct 24, 2011 #1 Can you join a directv and over the air antenna into a combiner so all tv's share over the air and directv receiver programing?
raoul5788 Studebaker driver Staff member HERE TO HELP YOU! Supporting Founder Lifetime Supporter Dec 28, 2004 33,104 18,421 Cheshire CT Oct 24, 2011 #2 Yes and no. It depends upon the model of receiver/dvr and the setup involved. Try doing a search for ota/diplexing. You should find an answer there.
Rey @ your service Supporting Founder Feb 8, 2008 27,003 586 Florida Oct 24, 2011 #3 i think as long as you're not using MRV its doable. here's info that will help you by using diplexers http://hr20.dbstalk.com/Slimline SWM ODU LNB First Look.pdf
TheTechGuru SatelliteGuys Pro Oct 30, 2010 1,862 226 Texas Oct 24, 2011 #4 If you're a SDTV only household it's quite simple. Install one of these just after the dish: SAM3402 MULTI-SWITCH [SAM3402] - $8.99 : ROXSAT, Toll Free 888-896-3236 Install one of these at each receiver: DTV(MSPLIT2R0)2WAY(2-2150Mhz)1 PORT PWR PASSING DTV Wide Band Splitter- 2 outputs [SPLIT2] - $8.75 : ROXSAT, Toll Free 888-896-3236
Rey @ your service Supporting Founder Feb 8, 2008 27,003 586 Florida Oct 25, 2011 #5 If he's an HDTV household he can do it as well. i have it.
