Joeys look terrible on SD tvs | SatelliteGuys.US
poor resolution. I installed 1h/2j the other day. I put 1 joey into 1080i res. and noticed this. so when i was installing the second joey i put it into 480i. same thing.
Huh? You have to explain that I think..... Maybe someone else hooked to an SD set can comment.
The problem is you can't change the guide to only show one and half hours of guide like you can on the 622 and 722. This makes the font bigger.
I have 2 Non hd TVS that are small. Pretty much not usable unless you walk up close
They need to add the guide adjustment option to fix this. They have it in there older models.
Guide data no longer tags events with premier
Hopper install advice
