Joey gets black screen, need to change channel or reboot hopper | SatelliteGuys.US
smakovits
177
8
Been fighting with this ongoing problem. I have 2 joeys and for the last month every day I am restarting the hopper or changing channels while watching a show in order to get the picture back.
Called dish, they said everything looks good with hardware. They said a technician can come check my connections, but that doesn't seem necessary. Got them to send me a new hopper, but that did not solve the issue either.
Any thoughts on what to check next?
Does the Hopper always show a picture? Check the MoCA signal strength. It sounds as though it's very marginal.
Hopper seemed to always work when I loaded I up. Then I started thinking about any changes and I may have found the culprit.
I have a power conditioner with catv, satellite and antenna connections. I rewired my rack and believe that is when I connected the hopper through it. And maybe that is when the issue started. (it has been a while and I just tell my wife reboot it, so I don't remember exactly is the 2 happened at the same time)
I undid this connection Friday and I think maybe it resolved the issue as I don't recall the black screen or the need to restart the hopper yesterday. Fingers crossed that it is resolved.
Reactions: Bobby and TheKrell
That's probably it. That line From the Hub to the Hopper shouldn't be interrupted, unless by a Tap
