Joey audio question | SatelliteGuys.US
Joey audio question
bowens
802
52
Florida
I'm having a Hopper and a Joey installed next week. The TV that will have the Joey is older and does not have HDMI, only DVI and composite audio. Will the composite audio out on the Joey still work with an HDMI cable plugged in? I know some devices disable other outputs when HDMI is plugged in. I've ordered an HDMI to DVI cable and then will use the composite out for audio.
Thanks.
You may have problems with the DVI input on your TV if it does not support HDCP. HBO requires it. There may be other channels that do as well.
By "composite audio", I'm assuming you mean the red and white analog stereo audio. There's also optical audio out on Joey that would work too if your TV has an input for it, or if you will be connecting audio to an A/V receiver.
Apps Problem
