Joey 3.0 have vertical stand? | SatelliteGuys.US
TainterGate
22
6
Washington
Wondering if the Joey 3.0 has a stand that can orient to vertical like the Joey 2.0?
And...anyone care to post actual "W x H x D" dimensions of the Joey 3.0?
Thank You
Thank you Bobby & Partysox for information. Current Joey 2's are installed in small hidden spaces mounted vertically on their own stands. When these Joey 2's get upgraded in a couple weeks I have to figure if the new Joeys can fit in existing space. Horizontal/flat is possible, BUT..., form & function is preferred!
Thank You
Hello TainterGate,
Here are the dimensions for the Joey 3.0: Height: .63".,Width: 7.5", Depth: 4.75". The optional mounting stand, measuring 0.38" H x 4.88" W x 4.88" D, allows you to mount the Joey vertically or horizontally. When used horizontally the stand can be attached to walls or the back of a TV for a low profile home entertainment setup. -Kim H.
Hello & Thank You Kim,
You mention an optional mounting stand available for the Joey 3.0? Is the mounting stand packaged with the Joey 3.0? Or is the mounting stand available A-La-Cart for extra purchase? I'm on a scheduled install to replace three of my Joey 2.0 with Joey 3.0's Nov. 24th. Thank You.
TainterGate, the mounting stands are available only for the Joey 1.0/2.0. The 3.0's were not designed to sit on a stand as they are much thinner. However, there is a opening under the Joey 3.0, where you may be able to have a screw placed on the wall and the Joey hung. I would just be sure to mention to the tech if we can get that done. -Christina W.
...Joey 3.0...The optional mounting stand, measuring 0.38" H x 4.88" W x 4.88" D, allows you to mount the Joey vertically or horizontally. -Kim H.
the mounting stands are available only for the Joey 1.0/2.0. The 3.0's were not designed to sit on a stand -Christina W.
Christina might want to let Kim know about that as well. ;)
Question on upgrade to Hopper 3
3rd QUARTER REPORT 2019
