You know what that means...
elsewhere there is talk that some may be very happy tonight... after a week with no CE's for the HR2x models I'm ready...
What good is MRV if you have two different types of rec's ?
At least yet, that is.
If I enable it on one rec. (if you have to) I won't know if it works until the other one gets it
Jimbo
It's a lot of good!
You have an H21 in a bedroom, and you can watch recordings on it from the living room.
should have holleredSorry for the delay, was on the road. Got the HR2x from the PDA, but waited till I got home to finish up.
It's a lot of good!
As the test goes on, it will be on any of the networkable H series (not-H20) and eventually, the other HR2x & R22 series, allowing you to view recordings from your other DVRs too.
It will be good, and get better over time![]()
Limited time offer
