Issue with Direct TV Install | SatelliteGuys.US
D.McGowan
Somerset, KY
Ok guys this makes the second time I have came across this problem. I am working with a appment were there is only one line ran into each room. Now my question is, hot to mirror a SD reciver to the second room with only one wire to each room. Can a diplexer be used or can it work or will it work or am I just dead in the water with the mirror.
The last job like this I just talked the customer into a second reciver used a swm dish with power inserter and used a 2 way splitter to the 2 sd recivers. But I have a lady this time that will not pay for the extra charge a month for the second tv so any help here would be greatful.
:welcome to Satelliteguys D.McGowan!
You can use an rf modulator to use a run of coax to the second tv. If she has an old vcr lying around, you can use it as a modulator.
I think you can diplex the back feed as long as they do not use whole-home DVR (MRV).
Whole-home dvr uses the same bandwidth as OTA so you can't diplex if they use MRV.
HR44/500 S/w 797 Kills local network.
DIRECTV CEO Mike White: 4K Rollout Will Be ‘Complex’
